Ana içeriğe geç
Toshiba Satellite C55D-B5206 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-B5206 Screen Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 2, 2 resimden 2.
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Screen Replacement, Screen: adım 3, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement, Screen: adım 3, 2 resimden 2.
    • Use a spudger to pry the top corner of the casing by performing an upward motion.
    • You will hear a loud click sound. Do not worry, this is the casing's clip.
    • The metal spudger could scratch your device. For the cautious fixers, use a plastic opening tool or black nylon spudger to pry the device instead.
    • Continue to remove the casing using your hands.
  4. Toshiba Satellite C55D-B5206 Screen Replacement: adım 4, 1 resimden 1.
    • Slide the spudger down the side of the plastic screen casing until you hit a clip.
    • Use the spudger and release the screen clips.
    • The clips will unlatch making a clicking sound each time you release one.
  5. Toshiba Satellite C55D-B5206 Screen Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 5, 2 resimden 2.
    • Repeat steps 1 and 2 on the other side of the casing.
    • The top and sides of the casing should now be un-clipped from the monitor.
  6. Toshiba Satellite C55D-B5206 Screen Replacement: adım 6, 1 resimden 1.
    • Gently close the monitor.
    • Turn the device around so the missing battery port is facing you.
    • Use the spudger and pry upward towards yourself.
    • You will here a click when the clips are detached from the monitor.
  7. Toshiba Satellite C55D-B5206 Screen Replacement: adım 7, 1 resimden 1.
    • Gently remove the plastic casing.
    • The casing should lift off with ease.
    • There are two hinge covers that you may need to maneuver off.
  8. Toshiba Satellite C55D-B5206 Screen Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 8, 2 resimden 2.
    • Use a Philips #1 screwdriver to remove the top left and right two 7 mm Phillips #1 screws by turning the screws counter clockwise.
  9. Toshiba Satellite C55D-B5206 Screen Replacement: adım 9, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 9, 2 resimden 2.
    • Gently pull the screen one inch towards yourself.
    • Detach the white cable from the camera in the center of the screen.
  10. Toshiba Satellite C55D-B5206 Screen Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 10, 2 resimden 2.
    • Use Phillips #0 screwdriver to remove the six, 2.5 mm screws on the bottom left and right, by rotating the screwdriver counterclockwise.
    • You will need to hold the screen upright so that it does not fall while removing the final three screws.
  11. Toshiba Satellite C55D-B5206 Screen Replacement: adım 11, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 11, 2 resimden 2.
    • Gently pull the screen downward to separate the screen from the back screen casing.
    • Gently grasp the cable that was removed from the camera and lift this cable upward.
    • There will be some tape that peels as you remove this cable from the back of the screen.
  12. Toshiba Satellite C55D-B5206 Screen Replacement: adım 12, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 12, 2 resimden 2.
    • Grip the large end of the brown cable.
    • Peel off the beige colored tape. Do not worry about ripping this tape.
    • Detach the black connector from the screen.
  13. Toshiba Satellite C55D-B5206 Screen Replacement: adım 13, 2 resimden 1. Toshiba Satellite C55D-B5206 Screen Replacement: adım 13, 2 resimden 2.
    • Use Phillips #0 screwdriver to remove three, 3 mm screws, on both side of the metal screen casing.
    • There are six total 3 mm screws. Three on each side.
  14. Toshiba Satellite C55D-B5206 Screen Replacement: adım 14, 1 resimden 1.
    • Lift the screen free from the casing.
    • There is no need for any pulling or tugging, the screen should lift out of the casing easily.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adam Walder
333 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 2,837
