Ana içeriğe geç
Toshiba Satellite C55D-B5310 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-B5310 Hard Drive Replacement, CD/DVD Drive: adım 1, 1 resimden 1.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  2. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the CD/DVD Drive out of the laptop.
  3. Toshiba Satellite C55D-B5310 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the thirteen 7 mm screws that secure the bottom cover.
  4. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you start from a corner, and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  5. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
  6. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 6, 3 resimden 1. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 6, 3 resimden 2. Toshiba Satellite C55D-B5310 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Remove the hard drive from the blue rubber mount.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 74
Her zaman: 3,138
