Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your keyboard is inoperable, use this guide to remove and replace the keyboard.
Neye ihtiyacın var
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
