Ana içeriğe geç
Toshiba Satellite C55D-C5106 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 1. Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 2. Toshiba Satellite C55D-C5106 Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 3.
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 2, 1 resimden 1.
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 3, 1 resimden 1.
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
  4. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 4, 3 resimden 3.
    • Use the metal spudger to remove the bottom cover of the laptop.
  5. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55D-C5106 Disk Drive Replacement: adım 5, 2 resimden 2.
    • Remove the disk drive by gently pulling it up and sliding it out.
Sonuç
Laura Tamayo
678 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 341
