Ana içeriğe geç
Toshiba Satellite C55Dt-A5306 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55Dt-A5306  Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 2, 1 resimden 1.
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306  Fan Replacement, Back Cover: adım 3, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 4, 1 resimden 1.
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 5, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 6, 2 resimden 1. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 6, 2 resimden 2.
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306  Fan Replacement, Fan/Heatsink Replacement: adım 7, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, unscrew four 3mm Phillips #0 screws, on the silver plate under the copper tubing.
  8. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 8, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, remove two 1.5mm Phillips #0 screw holding the fan down.
  9. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 9, 1 resimden 1.
    • After unscrewing, remove the heatsink from the laptop.
  10. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55Dt-A5306  Fan Replacement: adım 10, 2 resimden 2.
    • Unplug connected wire to remove the fan as indicated. Both the heatsink and fan should be removed before replacement.
Sonuç
Nahrain Putris
329 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 441
