Ana içeriğe geç
Toshiba Satellite C55Dt-A5306 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • After removing the battery, open up your device so that the keyboard is facing you.
  4. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 4, 2 resimden 2.
    • Using the spudger, go around the periphery of the keyboard while gently lifting out the keyboard little by little.
  5. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 5, 1 resimden 1.
    • Lift the old keyboard out of the way.
  6. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 6, 2 resimden 2.
    • Before pulling out the keyboard, notice that it is connected to the motherboard via a ribbon cable. Gently press out the ribbon cable from its connection site and put the old keyboard aside.
  7. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 7, 1 resimden 1.
    • Locate the keyboard ribbon cable, and the cable retainer keeping it attached to the motherboard.
  8. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 8, 1 resimden 1.
    • Use your nylon spudger to release the retainer by gently lifting the retaining clips on either side.
  9. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 9, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Keyboard Replacement: adım 9, 2 resimden 2.
    • Once both retaining clips have been lifted up, the ribbon cable should release with a gentle pull.
    • You can now remove the keyboard.
Sonuç
zeena qiryaqoz
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Bir Yorum
mein keyboard war leider noch mit 2 schraubenähnlichen Arretierungen befestigt, und die Laschen an den Seiten ließen sich nur mit Gewalt aufbiegen, so daß das alte Keyboard jetzt im Unterblech ziemlich verbogen ist. C55Dt-A5306
immerich - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 750
