Ana içeriğe geç
Toshiba Satellite C655-S5142 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: adım 1, 2 resimden 1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: adım 1, 2 resimden 2.
    • Unplug your computer, and make sure that it is shut off before starting.
    • Flip over your laptop, making sure the hard drive is facing you.
  2. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: adım 2, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the one screw holding the backplate on.
  3. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: adım 3, 2 resimden 2.
    • With a Phillips head screwdriver remove the final screw holding the hard drive in place.
  4. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: adım 4, 1 resimden 1.
    • To remove the hard drive, lift up the plastic tap attached to it and slowly pull up using your other hand as support.
Sonuç
Alex Kozlowski
244 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 329
