Giriş
This is a guide on how to remove a LCd screen from 15" Toshiba Satellite Laptop. Model # C655-S5212
Neye ihtiyacın var
First remove the stickers covers the screws in the 4 corners of LCD case. Stickers are very thin and using utility knife is easiest way to remove without damaging them. After removing stickers unscrew top 2 screws then proceed to Step 2 before trying to remove bottom 2 screws.
Remove 2 screws at bottom of LCD frame and also the 2 screws at top of LCD frame (not pictured). This will allow you to lay the back cover away from frame to access side easier and remove the 3 screws on each side to detach LCD screen. Do not pull LCD once unscrewed, lay down face down on keyboard for last step.
10 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Aoa sir....where to buy a new lcd screen for toshiba core i3??? Plz tell me
I usually get mine from Amazon or Ebay. On the back of LCD there is a sticker with the model number
