Ana içeriğe geç
Toshiba Satellite C655D-S5084 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Shelby Kunz
69 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G20
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 43
Her zaman: 3,540
