Giriş
Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
  1. Turn the laptop over and place upside down on a flat surface. Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
      • There are two tabs for each of the two RAM modules.
      • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  4. Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
Sonuç
3 başka kişi bu kılavuzu tamamladı.
Shelby Kunz
45 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-20, Maness Spring 2013 Cal Poly, Team 2-20, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G20
4 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 4
Son 30 Gün: 9
Her zaman: 2,533
