Ana içeriğe geç
Toshiba Satellite C675-S7106 CMOS Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 CMOS Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite C675-S7106 CMOS Battery Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: adım 3, 2 resimden 1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: adım 3, 2 resimden 2.
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0-head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 CMOS Battery Replacement: adım 4, 1 resimden 1.
    • Using a thin pry tool, gently remove the battery from its socket.
Sonuç
Joshua Steakelum
451 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 302
