Ana içeriğe geç
Toshiba Satellite C675-S7106 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C675-S7106 Hard Drive Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite C675-S7106 Hard Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite C675-S7106 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dinis Valcorba
292 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 400
