Giriş
Faulty or corrupted storage drives can be the root of many computer issues. Replacing it is an especially simple process in this laptop - you’ll just need a PH0-head screwdriver.
Neye ihtiyacın var
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
Rotate the laptop so that the battery cavity faces away from you.
Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
Bir başkası bu kılavuzu tamamladı.
