Ana içeriğe geç
Toshiba Satellite C675-S7106 Wireless Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C675-S7106 Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 2, 2 resimden 1. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Wireless Card Replacement, Keyboard: adım 3, 1 resimden 1.
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 4, 3 resimden 1. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 4, 3 resimden 2. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 4, 3 resimden 3.
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 5, 3 resimden 1. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 5, 3 resimden 2. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 5, 3 resimden 3.
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 6, 3 resimden 1. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 6, 3 resimden 2. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 6, 3 resimden 3.
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
  7. Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: adım 7, 2 resimden 1. Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: adım 7, 2 resimden 2.
    • Underneath the keyboard, gently disconnect the black and white wires on the right of the wireless adapter using a thin plastic spudger.
    • Be sure to properly re-connect the two wires during assembly, perhaps using the back end of the spudger to ensure that the connection is made.
  8. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 8, 1 resimden 1.
    • Unscrew the one 3mm screw in the top-left corner of the wireless adapter using a PH0 screwdriver.
  9. Toshiba Satellite C675-S7106 Wireless Card Replacement: adım 9, 1 resimden 1.
    • Lift the card up and to the right to remove it from the device.
Sonuç
Dinis Valcorba
292 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 UMass Dartmouth, Team S1-G2, Simcock Spring 2019 üyesi
UMASSD-SIMCOCK-S19S1G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 342
