Ana içeriğe geç
Toshiba Satellite C75D-A7370 Back Access Panel Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Toshiba Satellite C75D-A7370 Back Access Panel Replacement, Battery: adım 1, 1 resimden 1.
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 Back Access Panel Replacement: adım 2, 2 resimden 1. Toshiba Satellite C75D-A7370 Back Access Panel Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 Back Access Panel Replacement: adım 3, 3 resimden 1. Toshiba Satellite C75D-A7370 Back Access Panel Replacement: adım 3, 3 resimden 2. Toshiba Satellite C75D-A7370 Back Access Panel Replacement: adım 3, 3 resimden 3.
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 Back Access Panel Replacement, Back Access Panel: adım 4, 3 resimden 1. Toshiba Satellite C75D-A7370 Back Access Panel Replacement, Back Access Panel: adım 4, 3 resimden 2. Toshiba Satellite C75D-A7370 Back Access Panel Replacement, Back Access Panel: adım 4, 3 resimden 3.
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
Sonuç
Chris Purdie
428 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 47
