Ana içeriğe geç
Toshiba Satellite C75D-A7370 CMOS Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C75D-A7370 CMOS Battery Replacement, Battery: adım 1, 1 resimden 1.
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 3, 3 resimden 1. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 3, 3 resimden 2. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 3, 3 resimden 3.
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 CMOS Battery Replacement, Back Access Panel: adım 4, 3 resimden 1. Toshiba Satellite C75D-A7370 CMOS Battery Replacement, Back Access Panel: adım 4, 3 resimden 2. Toshiba Satellite C75D-A7370 CMOS Battery Replacement, Back Access Panel: adım 4, 3 resimden 3.
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
  5. Toshiba Satellite C75D-A7370 CMOS Battery Replacement, CMOS Battery: adım 5, 1 resimden 1.
    • Locate the CMOS battery.
    • Before handling internal components, please remember to properly ground yourself using an ESD strap to prevent electrical damage to sensitive components.
  6. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 6, 2 resimden 1. Toshiba Satellite C75D-A7370 CMOS Battery Replacement: adım 6, 2 resimden 2.
    • Then using a spudger, try to get under the battery and the battery will pop out of place. You are now ready to replace the CMOS battery.
Sonuç
Basim Ismail
201 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,032
