Ana içeriğe geç
Toshiba Satellite C75D-A7370 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C75D-A7370 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • To begin replacing your battery, flip the laptop over so that the back is visible. Locate the battery at the bottom center of the laptop.
    • Before beginning battery removal, make sure that no power source is connected to the laptop. This will avoid electrical shock.
  2. Toshiba Satellite C75D-A7370 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite C75D-A7370 RAM Replacement: adım 2, 2 resimden 2.
    • On the right side of the battery there will be a locking switch. Slide the switch into the unlocked position.
  3. Toshiba Satellite C75D-A7370 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite C75D-A7370 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite C75D-A7370 RAM Replacement: adım 3, 3 resimden 3.
    • Using your left hand, move the switch on the left side of the battery towards the center of the laptop while simultaneously prying up on the center of the battery with a spudger. The battery will flip out and can be removed.
  4. Toshiba Satellite C75D-A7370 RAM Replacement, Back Access Panel: adım 4, 3 resimden 1. Toshiba Satellite C75D-A7370 RAM Replacement, Back Access Panel: adım 4, 3 resimden 2. Toshiba Satellite C75D-A7370 RAM Replacement, Back Access Panel: adım 4, 3 resimden 3.
    • Remove the 7mm screw near the center of the back of the laptop with a P1 screwdriver and pry off the access panel with a nylon spudger.
  5. Toshiba Satellite C75D-A7370 RAM Replacement, RAM: adım 5, 1 resimden 1.
    • Using two fingers, push down on the aluminum rods on the sides of the RAM module
    • Before handling internal components, please remember to properly ground yourself using an ESD strap to prevent electrical damage to sensitive components.
  6. Toshiba Satellite C75D-A7370 RAM Replacement: adım 6, 1 resimden 1.
    • Gently pull the RAM module out of the laptop and repeat for the second module.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Purdie
428 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-1, Blackwell Spring 2017 USF Tampa, Team 16-1, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G1
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 537
