Ana içeriğe geç
Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: adım 1, 3 resimden 1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: adım 1, 3 resimden 2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement, WiFi / Bluetooth mini PCI express card: adım 1, 3 resimden 3.
    • Switch-off the laptop and remove the battery.
    • Use cutter and plastic tool to remove the Keyboard, held by 7x locking clips.
  2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 2, 3 resimden 1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 2, 3 resimden 2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 2, 3 resimden 3.
    • Remove 7x screws from the upper case.
    • Disassemble the HDD, RAM Memory cover and remove the HDD (just for safety).
    • Then remove 12x screws so you can start with disassembling the bottom case.
  3. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 3, 3 resimden 1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 3, 3 resimden 2. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 3, 3 resimden 3.
    • Use a plastic tool for separating the bottom case from the laptop.
  4. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 4, 2 resimden 1. Toshiba Satellite C850 - WiFi / Bluetooth half mini PCI express card Replacement: adım 4, 2 resimden 2.
    • Here is the WiFi, Bluetooth half mini PCIe card.
    • Disconnect 2x antenna cables (luetooth and WiFi).
    • The mini PCI card is held by one small screw.
    • Did you do it successfully?
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
3 Yorum
This card is mini pcie (express) not mini pci. A small quibble but it did cause me to waste time looking at it.
mknoy - Yanıt
You're right, my mistake.
ZFix -
This is a great explanation (exactly what I would have done), but I’m unable to find info on which pcie WiFi cards are compatible with C850. I want to install a 2400Mbps card, but uncertain if it will be compatible. Do you have any info/advice on this?
Matthew Rummins - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 67
Her zaman: 8,060
