Ana içeriğe geç
Toshiba Satellite C855-S5115 Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 7, 3 resimden 1. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 7, 3 resimden 2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 8, 1 resimden 1.
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 10, 1 resimden 1.
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 11, 1 resimden 1.
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 12, 1 resimden 1.
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: adım 13, 1 resimden 1.
    • Remove the CPU fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 43
Her zaman: 1,608
