Ana içeriğe geç
Toshiba Satellite C855-S5115 DVD Tray Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855-S5115 DVD Tray Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  2. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 2, 3 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 2, 3 resimden 2. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 2, 3 resimden 3.
    • Pry the back panel out of the laptop using the spudger tool
  3. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 3, 2 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 3, 2 resimden 2.
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  4. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 4, 2 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 4, 2 resimden 2.
    • Slide the HDD towards the sticker on the left.
  5. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 5, 2 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 5, 2 resimden 2.
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
  6. Toshiba Satellite C855-S5115 DVD Tray Replacement, DVD Tray: adım 6, 1 resimden 1.
    • Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
  7. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 7, 2 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 7, 2 resimden 2.
    • Insert a plastic opening tool and follow the edges to open the panel.
  8. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 8, 1 resimden 1.
    • Once open, locate the CD tray indicated in this picture.
  9. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 9, 2 resimden 1. Toshiba Satellite C855-S5115 DVD Tray Replacement: adım 9, 2 resimden 2.
    • Lift the tray up and out.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 31
Her zaman: 342
