Ana içeriğe geç
Toshiba Satellite C855-S5115 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 2, 1 resimden 1.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 4, 3 resimden 3.
    • Pry the back panel out of the laptop using the spudger tool
  5. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 5, 2 resimden 2.
    • Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
  6. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 6, 2 resimden 2.
    • Slide the HDD towards the sticker on the left.
  7. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite C855-S5115 Hard Disk Drive Replacement: adım 7, 2 resimden 2.
    • Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
    • Remove the hard drive from the tray.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,509
