Ana içeriğe geç
Toshiba Satellite C855-S5115 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855-S5115 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Keyboard Replacement: adım 2, 1 resimden 1.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Toshiba Satellite C855-S5115 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Carefully separate the keyboard from its assembly by pulling it out with the opening tool.
  4. Toshiba Satellite C855-S5115 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite C855-S5115 Keyboard Replacement: adım 4, 2 resimden 2.
    • Pull out the keyboard gently and fold it backwards.
  5. Toshiba Satellite C855-S5115 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite C855-S5115 Keyboard Replacement: adım 5, 2 resimden 2.
    • Pull out the connector attaching the keyboard to the main body of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
C855D-S5900 pry up the bottom of the keyboard, not the top. Installation is reverse of removal, put top of keyboard in, then snap in bottom.
Brandon Bates - Yanıt
Do you have to do anything with the connector before removing?
William - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 2,578
