Ana içeriğe geç
Toshiba Satellite C855-S5115 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855-S5115 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855-S5115 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 RAM Replacement: adım 2, 1 resimden 1.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 RAM Replacement, RAM: adım 3, 3 resimden 1. Toshiba Satellite C855-S5115 RAM Replacement, RAM: adım 3, 3 resimden 2. Toshiba Satellite C855-S5115 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Remove the single 7mm Phillips screw holding the panel in place using the J1S screwdriver.
    • Remove the back panel using the opening tool.
  4. Toshiba Satellite C855-S5115 RAM Replacement: adım 4, 1 resimden 1.
    • Gently push the metal hinges outwards from the RAM.
  5. Toshiba Satellite C855-S5115 RAM Replacement: adım 5, 1 resimden 1.
    • Pull the RAM out from the motherboard.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 33
Her zaman: 823
