Ana içeriğe geç
Toshiba Satellite C855D-S5109 Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 2, 2 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 3, 3 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 3, 3 resimden 2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 3, 3 resimden 3.
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: adım 4, 2 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 5, 2 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
  6. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement, Cooling Fan: adım 6, 2 resimden 2.
    • Remove the twelve 6 mm screws from the back of the laptop with a Phillips #00 screwdriver.
    • There are 12 screws holding the back panel on the laptop. Two of the screws are located underneath the service panel.
  7. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 7, 3 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 7, 3 resimden 2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 7, 3 resimden 3.
    • Remove the DVD RW Drive by sliding it out.
    • Use a jimmy to pry open the back panel.
    • Pull the back panel of the laptop off, exposing the motherboard and other inside components.
  8. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 8, 3 resimden 1. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 8, 3 resimden 2. Toshiba Satellite C855D-S5109 Cooling Fan Replacement: adım 8, 3 resimden 3.
    • The cooling fan is in the bottom right corner of the laptop.
    • Unplug the small red and blue wire connecting the cooling fan to the motherboard.
    • Remove the two 3 mm screws securing the fan to the motherboard with a Phillips #00 screwdriver.
    • Remove the fan from the laptop.
Sonuç
Brook Ostrander
169 İtibar
2 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-3, Lareau Fall 2021 Casper College, Team 1-3, Lareau Fall 2021 üyesi
CASC-LAREAU-F21S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 423
