Ana içeriğe geç
Toshiba Satellite C855D-S5109 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855D-S5109 RAM Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855D-S5109 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite C855D-S5109 RAM Replacement: adım 2, 2 resimden 2.
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite C855D-S5109 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite C855D-S5109 RAM Replacement: adım 3, 3 resimden 3.
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Flip the laptop around so that the bottom is facing you.
  5. Toshiba Satellite C855D-S5109 RAM Replacement: adım 5, 1 resimden 1.
    • Unscrew the Phillips #00 screw, and remove the back cover.
  6. Toshiba Satellite C855D-S5109 RAM Replacement: adım 6, 1 resimden 1.
    • Spread the metal clamps on either side of the RAM card outward so the RAM pops up.
  7. Toshiba Satellite C855D-S5109 RAM Replacement: adım 7, 1 resimden 1.
    • Pull the RAM out of the slot in a horizontal direction.
    • Be sure to only handle the edges of the RAM card, as the oils on your fingers can cause damage if they make contact with the face of the card.
Sonuç
Kaia Herrera
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 203
