Ana içeriğe geç
Toshiba Satellite C855D-S5303 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C855D-S5303 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Using a small Phillip's head screwdriver, unscrew the single 7 mm screw (5 mm head) on the L-shaped panel on the backside of the laptop.
  2. Toshiba Satellite C855D-S5303 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C855D-S5303 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Once the screw is removed, pry the panel upwards by gripping the groove pictured.
    • Be careful while removing the panel. Don't apply too much force when lifting as you may crack the plastic.
  3. Toshiba Satellite C855D-S5303 Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Satellite C855D-S5303 Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Satellite C855D-S5303 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Locate the hard drive. It is in a metal casing as pictured.
    • To remove, grab the right side of the piece and slide leftwards.
    • Lift up and out.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Courtney Burns
863 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 1,727
