Ana içeriğe geç
Toshiba Satellite C875-S7304 Battery Replacement
  1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C875-S7304 Battery Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C875-S7304 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite C875-S7304 Battery Replacement: adım 2, 2 resimden 2.
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 Battery Replacement: adım 3, 1 resimden 1.
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 Battery Replacement: adım 4, 1 resimden 1.
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 Battery Replacement: adım 5, 1 resimden 1.
    • Lift the battery out carefully using two hands.
Sonuç
Emma King
334 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 709
