Ana içeriğe geç
Toshiba Satellite CL15t-B1204X Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 2, 1 resimden 1.
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Hard Drive Replacement, Hard Drive: adım 7, 1 resimden 1.
    • Carefully unplug the cable near the USB on the left side.
  8. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 8, 1 resimden 1.
    • Delicately pull on the hard drive and the case it's in to unplug it from the motherboard.
  9. Toshiba Satellite CL15t-B1204X Hard Drive Replacement: adım 9, 1 resimden 1.
    • Peal the rubber casing around the hard drive off to completely remove the drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
What kind of joke is this?! Spent an hour taking my toshiba apart and THERE IS NO DRIVE IN HERE!!!! WTF
Hammerjockey Radios - Yanıt
Do we change ssd hearddisk 240gb with same ram
Kamal Badiyani - Yanıt
I agree with Hammerjockey Radios, you guys should be more clear. there’s no drive on this model.
Ernesto Filho - Yanıt
I started to think the drive was missing b/c my model is just -1204, not the 1204X version. But then I looked again at the pics above. There is NO DRIVE in their pics either! Not until steps 7-8 where you can see they layed one in there. Steps 3,4,5&6... There Is NO drive so why would you be taking the battery out? Even if there WAS a drive in this model, unnecessary manipulation of a lithium battery is not a wise move.
NDR - Yanıt
Puzzled that when i view the instructions there is NO hard drive when it is opened then it APPEARS suddenly. When I opened mine there was NO HARDDRIVE!!! After more research I discovered that the SSD is actually chips on a board that are soldered DIRECTLY onto the motherboard and CANNOT BE UPGRADED!!! My model is cl15t-b1204x. My crying begins NOW. Love my laptop but with updated on win 10 there is NO MORE ROOM not even for a single APPLICATION! Going to try to install win 7
Rick C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 3,093
