Ana içeriğe geç
Toshiba Satellite CL15t-B1204X Network Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite CL15t-B1204X Network Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 2, 1 resimden 1.
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 3, 1 resimden 1.
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 4, 1 resimden 1.
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 5, 1 resimden 1.
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: adım 7, 2 resimden 1. Toshiba Satellite CL15t-B1204X Network Card Replacement, Network Card: adım 7, 2 resimden 2.
    • Peel off the black antenna stuck to the card.
  8. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 8, 2 resimden 1. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 8, 2 resimden 2.
    • Carefully use the PH1 screw head to unscrew the one 3mm screw on the network card found near the hinge at the top.
  9. Toshiba Satellite CL15t-B1204X Network Card Replacement: adım 9, 1 resimden 1.
    • Remove the network card.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 248
