Ana içeriğe geç
Toshiba Satellite Click 2 Pro Wifi Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 2, 3 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 2, 3 resimden 2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 2, 3 resimden 3.
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 3, 2 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 4, 2 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 4, 2 resimden 2.
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 5, 3 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 5, 3 resimden 2. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 5, 3 resimden 3.
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 6, 2 resimden 1. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 6, 2 resimden 2.
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 7, 1 resimden 1.
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Wifi Card Replacement, Wifi Card: adım 8, 1 resimden 1.
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  9. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 9, 1 resimden 1.
    • Remove the black and white cables attached using ESD safe tweezers.
  10. Toshiba Satellite Click 2 Pro Wifi Card Replacement: adım 10, 1 resimden 1.
    • Remove wifi card.
Sonuç
Paul DeOrsey
893 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Spring 2016 UMass Dartmouth, Team 4-3, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 475
