Ana içeriğe geç
Toshiba Satellite E105-S1602 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E105-S1602 Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 2, 2 resimden 2.
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Disk Drive Replacement, Keyboard: adım 3, 3 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement, Keyboard: adım 3, 3 resimden 2. Toshiba Satellite E105-S1602 Disk Drive Replacement, Keyboard: adım 3, 3 resimden 3.
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 4, 2 resimden 2.
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 5, 2 resimden 2.
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 7, 1 resimden 1.
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 8, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 8, 2 resimden 2.
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
  9. Toshiba Satellite E105-S1602 Disk Drive Replacement, Front Panel: adım 9, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement, Front Panel: adım 9, 2 resimden 2.
    • Locate the four silver screws on the front panel.
    • Using the Phillips #0, unscrew to remove all four 2.95mm silver screws.
  10. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 10, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 10, 2 resimden 2.
    • Flip the laptop over and locate all seven screws on the bottom of the laptop.
    • Unscrew all seven Philips#00 7.70mm screws.
  11. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 11, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 11, 2 resimden 2.
    • Locate and unscrew the three silver Philips #00 2.85mm screws inside the battery compartment.
    • Locate and unscrew the five black Philips #00 3.25mm screws inside the battery compartment.
  12. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 12, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 12, 2 resimden 2.
    • Rotate the laptop so the back faces you.
    • Locate the two black Philips #00 7.65 screws, one by each hinge, and remove.
  13. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 13, 3 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 13, 3 resimden 2. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 13, 3 resimden 3.
    • Use the plastic opening tool to pry the top panel up from the base of the computer.
    • Slowly work your way around the computer with the plastic removing tool to make it easier to lift the top panel away from the base.
    • Carefully lift the top panel no more than six inches, as there are ribbon cables connecting the two pieces.
    • Disconnect ribbons, and slowly lift the top panel up, away from the base.
  14. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 14, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 14, 2 resimden 2.
    • Locate the ribbon cable from the motherboard.
    • Using plastic removing tools, pop the ribbon base from the motherboard.
  15. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 15, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 15, 2 resimden 2.
    • Locate the two plugs from the motherboard.
    • Using plastic opening tools, remove each plug from the motherboard.
  16. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 16, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 16, 2 resimden 2.
    • Locate the ribbon cable partially hidden under the front panel.
    • Using plastic opening tools, pop out the ribbon cable from the motherboard.
  17. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 17, 1 resimden 1.
    • Make sure that all wires have been disconnected before proceeding to avoid damaging components.
    • Slowly lift the top panel away from the base of the computer.
    • Place the top panel away from the computer and keep in a flat non-metallic surface until needed.
  18. Toshiba Satellite E105-S1602 Disk Drive Replacement, Disk Drive: adım 18, 2 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement, Disk Drive: adım 18, 2 resimden 2.
    • Locate and unscrew the Phillips-head #00 4.65mm screw that attaches the drive to the motherboard. It is located on the left hand side of the actual drive.
  19. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 19, 3 resimden 1. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 19, 3 resimden 2. Toshiba Satellite E105-S1602 Disk Drive Replacement: adım 19, 3 resimden 3.
    • Push to the right with your finger placed on the left side of the drive until it is completely removed.
Sonuç
Henry Smith
124 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-5, Cichon Spring 2014 UMass Dartmouth, Team 5-5, Cichon Spring 2014 üyesi
UMASSD-CICHON-S14S5G5
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 882
