Ana içeriğe geç
Toshiba Satellite E105-S1602 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Slide both of the latches to the outside to release the battery.
  2. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 2, 2 resimden 2.
    • Pull the battery out by lifting the battery cover away from the laptop.
  3. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Toshiba Satellite E105-S1602 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Flip the computer over and insert the plastic opening tool under the plastic strip at the top of the keyboard.
    • Pry the top plastic strip from the top of the keyboard.
    • Peel the strip completely away from the keyboard.
  4. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 4, 2 resimden 2.
    • Using your Phillips #00, unscrew the two 4.80mm screws at the top of the keyboard.
  5. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 5, 2 resimden 2.
    • When removing the keyboard, be careful not to rip the ribbon cable connecting the keyboard to the computer, to avoid damaging it.
    • Flip the keyboard up from the bottom in order to see the two ribbons connecting it to the motherboard.
  6. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tools, pop out the ribbon cable from the rest of the computer.
  7. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 7, 1 resimden 1.
    • Using the plastic opening tools, pop out the second ribbon cable from the rest of the computer.
  8. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite E105-S1602 Keyboard Replacement: adım 8, 2 resimden 2.
    • Completely remove the keyboard from the laptop by lifting up the part closest to the screen, and then gently pulling out the bottom half.
    • Keep the keyboard safe by storing it on a flat, non-metallic surface until needed.
Sonuç
Ian Washburne
59 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-21, Forte Winter 2013 Cal Poly, Team 17-21, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G21
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,553
