Ana içeriğe geç
Toshiba Satellite E45-B4100 Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Cooling Fan Replacement, Cooling Fan: adım 3, 1 resimden 1.
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD safe tools, we recommend using the iFixit Pro Tech Toolkit.
  5. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Disconnect the Cooling Fan from the Motherboard by gently pulling away on the white tab.
  6. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 6, 1 resimden 1.
    • Unscrew the two 3.75mm screws around the Cooling Fan and the copper attachment as shown with the #0 Phillip's Head screwdriver.
  7. Toshiba Satellite E45-B4100 Cooling Fan Replacement: adım 7, 1 resimden 1.
    • Remove the attachment from the Processor by gently rotating and lifting.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brendan Sweeney
182 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 594
