Ana içeriğe geç
Toshiba Satellite E45-B4100 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45-B4100 Hard Drive Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Pro Tech Toolkit
    $74.95
    Satın Al
    • Be sure to use ESD-safe tools, we recommend using the iFixit Pro Tech Toolkit
  5. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unplug the Hard Drive from the Motherboard.
  6. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
  7. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
    • Remove the USB Port Circuit Board.
  8. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 8, 2 resimden 1. Toshiba Satellite E45-B4100 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Gently remove the hard drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Delaney
104 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G4
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
By and large this and the B4200 guide are interchangeable. I followed both when reviving my B4100, as the pictures the respective authors show the components from different angle. Good stuff; thank you!
Kntai - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 2,397
