Ana içeriğe geç
Toshiba Satellite E45-B4100 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45-B4100 RAM Replacement, Battery Replacement: adım 1, 1 resimden 1.
    • Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
  2. Toshiba Satellite E45-B4100 RAM Replacement: adım 2, 1 resimden 1.
    • Gently pull out the battery.
  3. Toshiba Satellite E45-B4100 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Using a spudger, poke the white tabs in by the battery until you hear a click.
  4. Toshiba Satellite E45-B4100 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite E45-B4100 RAM Replacement: adım 4, 2 resimden 2.
    • Separate the laptop by sliding a spudger in between the black and silver covers.
    • Be sure to use ESD-safe tools, we recommend iFixit Toolkit.
  5. Toshiba Satellite E45-B4100 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45-B4100 RAM Replacement: adım 5, 2 resimden 2.
    • Pull the two metal brackets out away from RAM unit while simultaneously sliding the RAM unit out.
Sonuç
Brendan Sweeney
182 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Leahy Fall 2016 USF Tampa, Team 1-4, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 623
