Ana içeriğe geç
Toshiba Satellite E45-B4200 Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45-B4200 Speakers Replacement, Back Case: adım 1, 3 resimden 3.
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: adım 2, 2 resimden 1. Toshiba Satellite E45-B4200 Speakers Replacement, Speakers: adım 2, 2 resimden 2.
    • To remove the speakers from the motherboard, pull the speaker cables away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  3. Toshiba Satellite E45-B4200 Speakers Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45-B4200 Speakers Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45-B4200 Speakers Replacement: adım 3, 3 resimden 3.
    • Using a Phillips #0 screwdriver, unscrew the two screws from each speaker, that hold them in place.
    • You don't need to remove the screws, just unscrew them to the point that you're able to remove them from the device.
  4. Toshiba Satellite E45-B4200 Speakers Replacement: adım 4, 1 resimden 1.
    • Gently remove the speakers from the laptop. Make sure to disconnect the speaker wires from the frame prior to lifting the speakers out.
Sonuç
Raymond Makynen
289 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Ramos Spring 2023 UMass Dartmouth, Team 5-2, Ramos Spring 2023 üyesi
UMASSD-RAMOS-S23S5G2
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.
Any idea of what is the product code?
Thanks
MagenOne - Yanıt
Looks this H000079200
MagenOne -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 277
