Giriş
This guide will show users how to replace the battery in the Toshiba Satellite E45DW-C4210. It takes you step by step through the process of dissembling the laptop and reassembling it. You will need to unscrew the back then remove the back from the rest of the computer. You will also need to unscrew the battery, unplug the battery, and remove the battery. Then you will need to follow the steps in reverse order to reassemble the laptop.
Neye ihtiyacın var
Using a Phillips #0 screwdriver, remove all nine of the screws along the outside of the bottom of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
