Ana içeriğe geç
Toshiba Satellite E45T-A4300 Heat Sink Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: adım 2, 1 resimden 1.
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Heat Sink  Replacement, Heat Sink: adım 3, 1 resimden 1.
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: adım 4, 3 resimden 1. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: adım 4, 3 resimden 2. Toshiba Satellite E45T-A4300 Heat Sink  Replacement: adım 4, 3 resimden 3.
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
Sonuç
James Nguyen
573 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G4
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 247
