Ana içeriğe geç
Toshiba Satellite E45T-A4300 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the twelve 5 mm Phillips #1 screws from the back panel.
  2. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pry the back panel open with the plastic spudger or fingernails.
    • Pry it gently so that the back panel does not crack.
  3. Toshiba Satellite E45T-A4300 Motherboard Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the three 7mm black screws using the Phillips #1 screwdriver.
  4. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the hard drive’s connection port with grooved tweezers.
  5. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 5, 2 resimden 2.
    • Pull the hard drive out of the hook and remove it from the device.
  6. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: adım 6, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Fan: adım 6, 2 resimden 2.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
  7. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 7, 1 resimden 1.
    • Gently disconnect the fan cable from the device.
  8. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 8, 2 resimden 2.
    • Move the wires away from the fan’s hook.
    • Remove the fan from the device.
  9. Toshiba Satellite E45T-A4300 Motherboard Replacement, Heat Sink: adım 9, 1 resimden 1.
    • Remove the three 5 mm screws using a Phillips #1 screwdriver.
  10. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 10, 3 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 10, 3 resimden 2. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 10, 3 resimden 3.
    • Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
    • The heat sink is glued to a gray paste called thermal paste. Do not touch the paste.
  11. Toshiba Satellite E45T-A4300 Motherboard Replacement, Battery: adım 11, 1 resimden 1.
    • Disconnect the battery connector from the motherboard.
  12. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the single screw Phillips #1 screw near the battery.
  13. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 13, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the battery from the laptop.
  14. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: adım 14, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement, Motherboard: adım 14, 2 resimden 2.
    • Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
  15. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 15, 1 resimden 1.
    • Pull metal stick holder until it is upright.
  16. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 16, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
  17. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 17, 3 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 17, 3 resimden 2. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 17, 3 resimden 3.
    • Disconnect the six connectors from the device.
    • For the monitor port, pull it from the black tab.
    • For the connection port with the blue strip, lift the white placeholder before pulling the blue strip out of the connection port.
  18. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 18, 2 resimden 1. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 18, 2 resimden 2.
    • Pull out 2 plugs out from the wireless network card.
  19. Toshiba Satellite E45T-A4300 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
James Nguyen
573 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G4, Simcock Fall 2018 UMass Dartmouth, Team S1-G4, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G4
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 718
