Ana içeriğe geç
Toshiba Satellite E45t-B4204 Charging Port Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Charging Port Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Charging Port Replacement, Charging Port: adım 4, 1 resimden 1.
    • Locate the charging port housing.
  5. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 5, 3 resimden 1. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 5, 3 resimden 2. Toshiba Satellite E45t-B4204 Charging Port Replacement: adım 5, 3 resimden 3.
    • Unplug the charging plug housing from the motherboard.
Sonuç
Eduardo
411 İtibar
4 adet Kılavuz yazıldı
Ekip
Bir Yorum
You didn’t complete the instructions. It ended after you said unplug the charging port housing. The pictures are not clear. Please add red lines or arrows, etc. to show what you are trying to do. It doesn’t show or spell out the next steps to replace it.
Correy Smith Hartzog - REALTOR - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 3,272
