Ana içeriğe geç
Toshiba Satellite E45t-B4204 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Fan Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Fan Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Fan Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Fan Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Locate the fan.
    • The fan is a grey plastic with a black circular fan in the center.
  5. Toshiba Satellite E45t-B4204 Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite E45t-B4204 Fan Replacement: adım 5, 3 resimden 3.
    • Remove all 4 mm screws with a Phillips #1 screwdriver.
  6. Toshiba Satellite E45t-B4204 Fan Replacement: adım 6, 2 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement: adım 6, 2 resimden 2.
    • Locate the red, black, and yellow wire connecting to the motherboard.
  7. Toshiba Satellite E45t-B4204 Fan Replacement: adım 7, 3 resimden 1. Toshiba Satellite E45t-B4204 Fan Replacement: adım 7, 3 resimden 2. Toshiba Satellite E45t-B4204 Fan Replacement: adım 7, 3 resimden 3.
    • Unplug the wire from the motherboard. Once it is unplugged you will remove the fan.
Sonuç
Perla Ruiz
159 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 272
