Ana içeriğe geç
Toshiba Satellite E45t-B4204 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 5, 2 resimden 2.
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 6, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 6, 2 resimden 2.
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 7, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 7, 2 resimden 2.
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 8, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 8, 2 resimden 2.
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 3.
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 10, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 10, 2 resimden 2.
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 11, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 11, 2 resimden 2.
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 12, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 12, 2 resimden 2.
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 3.
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 3.
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 3.
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 16, 1 resimden 1.
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 17, 1 resimden 1.
    • Remove the keyboard.
Sonuç
Youdong Yan
229 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 üyesi
IUPUI-WILSON-SU19S3G3
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 614
