Ana içeriğe geç
Toshiba Satellite E45t-B4204 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 RAM Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 RAM Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 RAM Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 RAM Replacement, RAM: adım 4, 3 resimden 1. Toshiba Satellite E45t-B4204 RAM Replacement, RAM: adım 4, 3 resimden 2. Toshiba Satellite E45t-B4204 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Locate the RAM. The RAM will be covered by a black protective plastic. Once it is located, the protective plastic will be lifted up exposing the RAM.
  5. Toshiba Satellite E45t-B4204 RAM Replacement: adım 5, 3 resimden 1. Toshiba Satellite E45t-B4204 RAM Replacement: adım 5, 3 resimden 2. Toshiba Satellite E45t-B4204 RAM Replacement: adım 5, 3 resimden 3.
    • On the ends of the RAM, there are small clips. Click the small clips by pushing them away from from the RAM. Once the RAM has been clicked off gently pull out and remove.
Sonuç
Eduardo
411 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 928
