Ana içeriğe geç
Toshiba Satellite E45t-B4204 Speaker Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Speaker Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: adım 4, 3 resimden 1. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: adım 4, 3 resimden 2. Toshiba Satellite E45t-B4204 Speaker Replacement, Speaker: adım 4, 3 resimden 3.
    • Unscrew the 4 screws at the sides of each speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the speaker cable from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo has the potential to damage your device.
  6. Toshiba Satellite E45t-B4204 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the speakers.
Sonuç
Emily Bateman
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 üyesi
IUPUI-WILSON-SU19S3G3
4 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks for the guide, but looks is missing some main parts, the product code of the speaker.⏎
Before I disassembly something I want to buy the replacement, by searching for "toshiba e45-b4200 speaker" I only find some presumably compatible speakers, with different shape.⏎
Any idea of what is the product code?⏎
Thanks
MagenOne - Yanıt
Looks this H000079200
MagenOne -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 702
