Ana içeriğe geç
Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Battery: adım 1, 2 resimden 2.
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 2, 1 resimden 1.
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, Bottom Case: adım 3, 1 resimden 1.
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 4, 1 resimden 1.
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 6, 1 resimden 1.
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: adım 7, 3 resimden 1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: adım 7, 3 resimden 2. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement, USB HDMI Audio Circuit Board: adım 7, 3 resimden 3.
    • Use the point end of the spudger to lift the clips that attach the two ribbons to the motherboard.
    • Pull out the ribbons from the motherboard.
  8. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 8, 2 resimden 1. Toshiba Satellite E45t-B4300 USB HDMI Audio Circuit Board Replacement: adım 8, 2 resimden 2.
    • Unscrew the 2mm screw with a Phillips #0 screwdriver.
    • Remove the circuit board.
Sonuç
Joshua Swanson
701 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Sullivan Spring 2017 USF Tampa, Team S2-G2, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S2G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 342
