Ana içeriğe geç
Toshiba Satellite L15W-B1208X Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite L15W-B1208X Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite L15W-B1208X Battery Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: adım 3, 3 resimden 1. Toshiba Satellite L15W-B1208X Battery Replacement: adım 3, 3 resimden 2. Toshiba Satellite L15W-B1208X Battery Replacement: adım 3, 3 resimden 3.
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: adım 4, 3 resimden 1. Toshiba Satellite L15W-B1208X Battery Replacement: adım 4, 3 resimden 2. Toshiba Satellite L15W-B1208X Battery Replacement: adım 4, 3 resimden 3.
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 658
