Ana içeriğe geç
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: adım 1, 3 resimden 1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: adım 1, 3 resimden 2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: adım 1, 3 resimden 3.
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: adım 2, 3 resimden 1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: adım 2, 3 resimden 2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: adım 2, 3 resimden 3.
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: adım 3, 1 resimden 1.
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: adım 4, 1 resimden 1.
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: adım 5, 1 resimden 1.
    • Remove the board from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yanchen Li
121 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 288
