Ana içeriğe geç
Toshiba Satellite L15W-B1303 USB Port Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: adım 1, 3 resimden 1. Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: adım 1, 3 resimden 2. Toshiba Satellite L15W-B1303 USB Port Replacement, Bottom Panel: adım 1, 3 resimden 3.
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 USB Port Replacement, USB Port: adım 2, 1 resimden 1.
    • Disconnect the cable that connects the receiver to the laptop using the pointed end of a spudger.
  3. Toshiba Satellite L15W-B1303 USB Port Replacement: adım 3, 1 resimden 1.
    • Remove the single JIS #00 screw.
  4. Toshiba Satellite L15W-B1303 USB Port Replacement: adım 4, 2 resimden 1. Toshiba Satellite L15W-B1303 USB Port Replacement: adım 4, 2 resimden 2.
    • Peel back the material covering this wire.
    • Gently pull the board out carefully to avoid damaging the connector.
Sonuç
Justin Caruso
147 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 540
