Ana içeriğe geç
Toshiba Satellite L15W-B1320 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L15W-B1320 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite L15W-B1320 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite L15W-B1320 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
Sonuç
Elizabeth Zapata
190 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,348
