Ana içeriğe geç
Toshiba Satellite L15W-B1320 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 4, 1 resimden 1.
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Sonuç
Elizabeth Zapata
190 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Excelente tutorial... más especifico no podría ser
Muchas gracias por compartir el conocimiento..
Luis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,382
